Sportivo Tyre Pressure
SPTIVO_LUVA
Hey all, i am trying to figure out my tyre pressure, last time i did it, i put roughly 32 psi, but it did not look like enough, what do most ppl put in theres?
NOTE. SORRY I CLICKED WRONG SECTION PLEASE MOD MOVE TO WHEELS & TYRES
Edited by SPTIVO_LUVA
how are you measuring it?
If you are trusting the digital readout from the servo self inflater... forget it... invest in a spring dial pressure gauge (~$8 from any auto shop) and test the pressure after it's inflated, you will find it wavers around some times.
i thought the digital ones which beep at the set point were good. i know the analog ones which ding at the set point were not accurate since the handle which contains the gauge was always dropped. i heard that if you need to drive to the servo to get to one within 8 km of cold tyres or they heat up too much.
BP servos usually have a tyre inflator with digital reading that beeps (as kcorro indicated in previous post) and/or blinks when the desired pressure's been reached.
a few things that i would always keep in mind to keep the tyres from heating up too much on the way to the servo:
1. drive to a servo within 1 mile (1.6 km) of cold tyres
2. don't drive faster than 40kmh and try to minimise the stop n go
3. the colder the weather, the better
4. redo the tyres at least once in case it didn't "sense" the tyre pressure correctly the first time
      Stout Owners
      New Member
    4. 199
      Current Oil Specials
      Advice Please
      Fortuners Transmission
    7. 199
      Advice Please
      A Greenskin
