Painting calipers yellow
JAZE55
Im planning to spray my calipers yellow, as red is to common. Does anyone with a black stivo done this before. If so can you please post pics, as i would like to see them before i do it. Ive seen pics of lambos and porches with yellow calipers and they look the shizzle, but not to certain how they will look on the rolla. Pics please
if not yellow then blue..........
Seen yellow before, bro it just gets ugly once it gets dirty.
Went today aond got some red 1500 f paint bust spraying now.
Red will always look the best
Edited by CORZZA
Ok then, I dont want that. I think im just gonna go with blue to match my blue theme of coilovers and strut brace. :P :P I seen how they look in sportiv car awesome and not over the top. :)
is there anyone or that can recommend me to someone that can paint my calipers aswell as my rotors (hud) rotors is where the bolts are for your wheels...ummm how can i say this...between the wheel and the disc break......would anyone know a good place to go?
serious? lol i got some at home hahah
if u can't find caliper paint just buy high temp paint.
black looks best!
Thnx Vyets i just checked out VHT brochure and i can get gold hi temp 1500F (815C)paint hehe. GOLD FTW :clap:
I used the VHT Flame proof paint.
Flat red not the usual glossy red most use and it looks mint!
No problems with peeling,fading or staining at all.
Did it all my self! Wheel off newspaper and spray,spray,spray!
Make sure you get fair bit of coats on it!
I used 3/4 of a can on both my front callipers
Yep i just did mine in GOLD, took 3hrs alltogether. The cleaning and prep work is the most time consuming part, but worth it. I did 4 coats looks a treat. Not sure about doing the rears as they are very small.
I just finished doing my calipers red (white car, seemed to be a good option, although that gold looked excellent!) When I say just finished, I mean the car got put back in the garage an hour ago after a quick hill run to clear the overspray off the surface of the brake dics!
While I was there, I also did the hubs silver again as there was a touch of corrosion on them and it was looking a little ratty - especailly the rears.
I used a bit over half a can of red (Septone 400g brake paint - Super Cheap Auto about $16) to do the front and rear calipers and another can of silver (less than half a can) to do the front and rear hubs - 3 coats on the lot. For the hubs, I used a finish they call aluminium.
With a can of degreaser for cleaning, two sheets of wet & dry sandpaper and the two aersol cans, my overall job budget was about $37. Camera phone pics don't do it justice - but will post some pics if anyone is interested (and can point a newbie in the right direction re: posting pics).
Cheers,
Nath.
      Where is the remote receiver on a 1998 Camry
    2. 27
      1987 Toyota Corolla - 60 000km on the clock
    4. 3
    5. 3
      Toyota Landcruiser problems
    7. 13
      300 series turbo issues
    8. 55
      Stout Owners
    9. 13
    10. 8
