1.5zzfe motor...
Guest JDM y0 !
i know that 1jz heads are put on 2jz blocks but yes they have the same bore and stroke.
would be hard to do with the 1zz and 2zz as they are different.
i know people put 2zz into mr-s . my friend in singapore has a mr-s with a 2zz and a turbo kit that retains the stock compression with low boost.
i'd like to see this mr-s
Guest JDM y0 !
his name is **** and he was an exchange student in melbourne who attended rmit.
if that helps. if you think you know the guy then pm me shaohaok.
Edited by JDM y0 !
1JZ and 2JZ don't have the same stroke. They have the same bore though, which is what allows the head swap.
Guest JDM y0 !
hehe my bad :)
lol if they had the same bore and stroke then they would both be the same capacity.........lol i made quite the fool of myself !! (embarresed highly)
edit..............the MR T in my avitar is pittying me ! (i pitty the foo !)
Edited by JDM y0 !
the car was white with the trd stickers on the side.. and on the back window lookd like a aussie flag...
also i do recall it was powerd by m800 motec unit...
umm.. which mag? start with J... J TUNER? i think it was a britsh mag.. saw it in burwood westfields.. the newsagent on the 3rd floor....
      ZRE182 Nudge bar
      2016 Hilux SR5 Coolant Issues
      What to say!
    7. 4
    8. 4
      RATTLING CAMRY 2013
