Springs/towerbrace/rear sway
oncy
hi
ive just bought my self grimlocks tower brace and rear sway and i have springs sitting here.
i was just wondering should i put the springs on fist b4 putting on the strut and sway bar OR
the other way round ??
or it doesnt really matter which way i put it on
any input much appreciated
cheers jonno
the rear sway bar can be done at anytime but you may like to try it first because the bolts securing it usually very tight.
you should install the springs before the front tower bar since that will save you from having to take it off.
yep, its better to have your springs in first b4 your front strut becuz u need to take the strut brace off to get the front springs in, rear bar u can do it any time but make sure u have them really tight, otherwise it will make some noise
      Stout Owners
      New Member
    4. 199
      Current Oil Specials
      Advice Please
      Fortuners Transmission
    7. 199
      Advice Please
      A Greenskin
