Mobile Phone/Radio Connection
cssjamin
I have an Aurion and have installed a mobile phone bluetooth, in its basic form.
Wondering if anyone either has a wiring diagram, knows where the wiring loom for this is located or knows where i can connect the mute wire, such that the radio will mute when a call is made.
Any assistance would be appreciated
Regards
Q: I was told that the mic is already installed next to the overhead sunglasses compartment, is this true. Or is it just a space where there allowing for one ?
If I find a wiring diagram, i'll let you know.
Adrian
Hi Adrian,
Your probably right about the mic near the sunglasses holder. I might check on the weekend.
As for the wiring diagram, appreciate it, if you come across one.
Even if you find out where they hide the loom. Generally it should be there somewhere, for upgraded models. Its just a matter of knowing where it is :)
Thanks again
  • 7 months later...
Hey - I've just got the Touring edition delivered and I can see (when sunlight hits the radio) the little pictures in the radio for Bluetooth as if the 6 stacker CD player supports bluetooth. Does anyone know if you can add bluetooth to this sytem????
I'm not sure where it is as i don't have an aurion...but it's usually labeled as the "ATT" wire on the back of the head unit. in most after market HU's, it's the single yellow wire. hope this helps.
Edit: Ooops, correction. I think the "ATT" wire might be the antenna wire...I've confused myself now; it's been a few years since I installed an aftermarket HU. but it should still be a single wire
Edited by qkslvr
Wiring diagram CD release from Toyota will be available from November this year. if you want to know.
The release CD is from 1 year from release of car.
I have made inquires for this already, and was told not tell 1 year has past.
      Classic Toyota
    5. 30
      FUEL WARNING MESSAGE
    6. 30
      Classic Toyota
    9. 30
