Hi everyone, this is my first post.
I have a 1998 Camry CSI 3.0L V6. Yesterday, I just made a second cold air intake by myself :D (see photos), cut 2 holes and run 2 pipes down to front of front wheel. I have ordered a K&N air filter, it should be arrive next few days. Can't wait for it.
What do you guys think?
cool idea but why did u decide to have a 2nd CAI and not just make the one pipe bigger?
The reason why I did it that way is because it is easy to do (DIY), and I dont want to spend to much money for it (spend to something else :D ). I used 2 small pipes for easy access to small gaps under air intake box.
The idea is from my brother, he has an BA Falcon XR6 with a second CAI. What he did is bought a second CAI from FPV Typhoon, drilled a hole and fixed it in, quite easy.
I still haven't got the K&N air filter yet, hopefully it arrives next few days.
Next step is exhaust, one exhaust shop quoted me $300 for mild steel hi-fow cat or $350 for stainless steel one, 2.25 inch exhaust system for $300 or $550 with the cat. Is it expensive? what you guys suggest?
Thanks in advance
That sounds quite reasonable for a press-bent system from a hi-flow cat. To get a full system with some form of headers and mandrel-bent, you're looking at over $800, + cost of a new cat. I wouldn't really bother getting a full system; it's really just about noise as any gains will be fairly minimal.
Thanks in advance
thats a fair price. then i would suggest you getting a piggyback.
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
