Kaixen Xenon H11 kit arrived toda. Instruction manual says that I need to change fuses to 20A. I'm not sure which fuses should be changed. Can anybody confirm if the circled fuses are the right ones.
I don't want to be blunt, but you could have EASILY answered you own question by taking a few simple minutes to look at your own car. The fuse box has a diagram on it will confirm your diagram they sent you. And by the way, I wouldn't bother changing to 20A fuses unless you experience issues. 15A fuses that are already there is more than what you need.
Thanks for that . I had a look at that but couldnt figure out the abbreviations. :unsure:
    2. 0
    3. 9
      Android auto
    4. 9
      Android auto
    5. 1
      Turboed Corolla Overbuilt?
    6. 3
    7. 3
    9. 18
