DIY foglight install with OEM headlight dimmer stalk
Error Codes - 200 Series Landcruiser
Hey guys, just wondering if anybody has had theres error codes - 7E8 and 7E9 come up on their 2009 -200 series Landcruiser turbo diesel. Any ideas on what they could be? Have tried searching online but am receiving mixed information. Any help is much appreciated- errorcodes
- 200series
(and 1 more)
Tagged with:
Android auto not working Toyota corolla ascent sport hybrid
are there anyone to help ? -
- 200series
(and 1 more)
Tagged with:
Looking for a set of rim's for my 80 series. What else will
What rim's will fit that aren't Toyota -
programming a new transponder chip
one of the remotes for my keys recently broke after I was out working in the rain so I decided to upgrade to a flip key that I purchased on eBay that was listed as compatible with my vehicle a 2009 Toyota Kluger kx-r. I was able to program the remote part with a combination of opening and closing the door as well as putting the key in the ignition and that all worked perfectly fine. However I am having some difficulty programing the transponder chip into the car in order to get it to start could anyone give me some advice as to how to do this as I have tried a number of methods with no results. Thanks -
Both license plate bulbs not illuminating?
Given that both bulbs are not illuminating, I would check the fuse first. Why? Because it is easier to do that instead of replacing the bulbs. From experience, when it has only been 1 bulb not illuminating, i start by either swapping the bulbs or just replacing the bulb first up. -
Toyota Corolla Allex Tweeters
Hi all, I wanted to upgrade my car’s front speakers, on the website it says my car has the option to have tweeters, and I checked at the housing at the mirror, however when the current panel is moved it seems the space is taken up? I’m new to this, so I’ll take any help. wanted to get the fosgate from Crutchfield, comes with tweeters its an 04 corolla allex, 1.8l, zze122- toyota sportivo
- toyota corolla
(and 3 more)
Tagged with:
I don't know about 2013s but my initial reaction is to try switch them out incase they are blown. -
Hey peeps, I purchased a 2013 Toyota Camry. Both seperate light bulbs for the licence plate are not illuminating. Ideas on the issue? Steps to solve? Could it be a fuse? I assume if it was a fuse other lights would also be out? On that note the transmission option light inside is also out (drive, park so forth). Any advice appreciated. -
Prado - cracked piston on diesel model at 120k?!?!?
Hi I had the same 2009 to 2015 have the same problem. Toyota Broome fitted a new motor different shape cylinder head car runs great $10800 it should , they tried for warranty but Toyota said to many ks 320000
