Posted (edited)
Hi All,
After some input here...
Looking to change the OEM Toyota Battery with one of the following;
- Supercharge MF80D26L 650CCA 125RC http://www.supercharge.com.au/product_detail.php?seq=54
- AC Delco S80D26L 600CCA 70Ah 130RC http://www.acdelco.com.au/PDFs/Catalogue_ACDelco_Batteries_22-07-09.pdf
- Century NS70L 520CCA 110RC http://www.centurybatteries.com.au/files/All_PDFs/NS70L_Century_Spec%20Sheet.pdf
- Century NS70LX 545CCA 130RC http://www.centurybatteries.com.au/files/All_PDFs/NS70LX_Century_Spec%20Sheet.pdf
- Exide N50ZZL 600CCA 120RC http://www.exide.com.au/fitment/index.php
- Varta Blue dynamic E23 5704120633132 630CCA 70Ah http://www.varta-automotive.com/index.php?id=258&L=
The dimensions (max) (L) 261mm (W) 175mm (H) 220mm
What are your thoughts, experiences guys...
Or what have I missed?
Edited by ope126
The Varta or Black MF AC DELCO battery would be my choice. I just purchaced a Seal Calcium ROCKET battery (same as AC DELCO) to put in my Gen 1 Kluger. Been selling them for years and they seem pretty good.
Hi, thanks for your input.
I am considering the AC Delco, good specs and only $119.00.
However I like the idea of the Bosch S5, however it is not available in OZ yet.
The S4 is though and you can go past these specs and the cost is $195...
Ok, so new battery is now installed.
I was after the Bosch S5 110D26L 680CCA 90Ah 160RC, however it is unavailable in OZ until September 2010.
So I went with the following; Bosch S5 90D23L 650CCA 75Ah 125RC $170.00AUD.
The only difference is it is only 240mm long, where the 110D26L is 261mm long. No real biggie.
These batteries are for Camry, Aurion, Torago etc.
The OEM Panasonic / Toyota Battery is only 420CCA.
Posted (edited)
Would you consider it a reasonable request if I asked for a brief run down on the specifictions of the average battery (as listed above) so that I and maybe other battery noobs may be better educated? please...unsure.gif
Edited by whofan
      Android auto
    2. 9
      Android auto
    3. 1
      Turboed Corolla Overbuilt?
    4. 3
    5. 3
    6. 0
    7. 18
    8. 5
      Tow bar
