Hi all
As the AVN726EA is common in Toyotas I thought i'd ask this here.
I just put an AVN726EA into my 2010 SR5 Hilux. Works great.
Now I want to put one in my V2 CV8 (Monaro). However I don't want the Eclipse reversing camera.
I have found a really good camera that mounts off the number plate but it uses a BNC connector.
Does anyone know of an adapter to change from the AVN726EA input plug to a standard BNC cable and power supply cable?
Yes it can be done but you will most likely need to make that adaptor lead yourself. Where are you located?
Newcastle area. I can make one (i'm an electrician and electrical engineer) but I don't have the plug for the camera input to the head unit.
You will need to hit up your car audio shops and see if they will give you a plug. There are 4 wires in that plug: 5v, 12v, video, earth. Whats wrong with the eclipse camera good qaulity plugs straight in?
Nothing, works fine on the Hilux. Just will look ugly as on the Monaro. I've found a place in the USA that sells a genuine Eclipse adapter, just waiting to see if they'll post it over here.
    2. 0
      Remote start
    3. 1
    4. 0
    5. 9
      Android auto
    6. 9
      Android auto
    7. 1
      Turboed Corolla Overbuilt?
    8. 3
    9. 3
    10. 0
