TOYOTA COROLLA ZZE123 SPORTIVO
SPECIFICATIONS
Category
Small Passenger
Body
4 door 5 seat Hatchback
Transmission
6 speed Manual (Front Drive)
Engine
1796 cc (1.8L) 4 cylinders
Origin
South Africa
Released
MAY 2003
WARRANTY
Warranty - description
3 yr, 100,000km; 3 yr on paint, 3 yr on perforation corrosion.
Minor service interval (oil change - km)
10000
Major service interval (km)
40000
ENGINE
Engine location
Front
Engine orientation
Transverse
Engine description
Four cylinder, in-line, chain-driven DOHC, four valves per cylinder, variable valve timing with lift, all alloy.
Configuration
In-line
Cylinders
4
Valve train
DOHC
Valves per cylinder
4
Variable valve actuation
Timing and lift
Block material
Aluminium alloy
Head material
Aluminium alloy
Capacity (cm3)
1796
Bore (mm)
82.0
Stroke (mm)
85.0
Compression ratio
11.5:1
Maximum power
141kW @ 7800rpm
Maximum torque
180Nm @ 6800rpm
Induction system
Electronic sequential port fuel injection
Fuel type
95 RON ULP
Fuel tank capacity (litres)
60
SUSPENSION
Suspension/front description
Independent, MacPherson struts, fabricated steel lower L-arms, steel sub-frame, coil springs, gas dampers, jointed mount anti-roll bar.
Suspension/rear description
Semi-independent, torsion beam, fabricated steel trailing arms, coil springs, gas dampers, enclosed anti-roll bar.
Sports suspension
STD
STEERING
Steering description
Rack and pinion, power assisted
WHEELS
Front brake description
Ventilated discs
Front - diameter (mm)
275
Rear brake description
Discs
Rear - diameter (mm)
279
Rim material
Alloy
Front rim description
6.0JJx16
Rear rim description
6.0JJx16
Front tyre description
195/55 R16 87V
Rear tyre description
195/55 R16 87V
COUNTRY OF ORIGIN
Country of origin
South Africa
HOW BIG
Body construction
Monocoque
Length (mm)
4175
Width (mm)
1695
Height (mm)
1470
Wheelbase (mm)
2600
Track - front (mm)
1480
Track - rear (mm)
1460
Kerb mass (kg)
1224
GVM (kg)
1630
Seating capacity
5
Shoulder room - front (mm)
1430
Head room - front (mm)
945
Head room - second row/rear (mm)
940
Luggage capacity - seat up (litres)
271
Towing capacity - with brakes (kg)
950
Towing capacity - without brakes (kg)
450
TRANSMISSION
Transmission description
Six speed manual
Transmission type
6 man
Ratio 1
3.166:1
Ratio 2
2.050:1
Ratio 3
1.481:1
Ratio 4
1.166:1
Ratio 5
0.916:1
Ratio 6
0.815:1
Reverse
3.250:1
Final drive ratio
4.529:1
Final drive location
Front
Sourced from: http://www.carpoint.com.au/new-car/TOYOTA/...9375&View=3
The rear discs are infact not that large. There is a thread where people were arguing about it a while back. Think Shao said they are the same size as the 1zz rear rotors (269mm?)
Edited by SuperDave
does any one know why the Japanese Corollas have a 5 year paint and corrosion warranty while the South African one only has a 3 year warranty.
After polishiong the stivo however there are so many paint imperfections I think I can understand why.
Anyone any idea? :)
      Just joined
    2. 2
      2016 Hilux SR5 Coolant Issues
    3. 2
      Son's First Car--98 Corolla Seca--Overfilled Oil--Cactus??
    4. 2
    5. 1
      Toyota Camry Keyless Entry Door Control Receiver
    6. 0
      ZRE182 Nudge bar
    7. 0
      2011 Hilux fuel injector seals
    8. 2
    9. 2
    10. 1
      What to say!
