1998 toyota camry conquest v6 exhaust?
TJtoyota
A supercharger running 6psi and lots other supporting mods for it to run.
And a 5sp swap.
It would be making more power now. Haven't had a dyno for a while and needs a tune again quite badly
Edited by STYLSH
Do they make straight bolt on supercharger kits for the camry
Somewhat bolt on. There is other work required and they are expensive to find one in a decent condition as they can not be bought new.
The pipe from throttle body to the back of the battery are all the same between the brands. I got the cold air extension to the guards custom made 2.5in diameter but 3in right at the end to fit a bigger pod filter.
Flowed enough to make 170kw atw on the car.
You should get a new silicon join for the top as that rubberones have gotten hard with the hot cold cycles.
You should get new silicon joins as these rubberones have gotten hard with the hot cold cycles.
Is that your older CAI set up in that picture? I am looking at buying a CAI at the moment if your wanting to sell, are you from Australia?
Hey guys got my hands on a high flow cat for free off a mate, will fitting the cat to my camry v6 make it louder? I don't wanna put it on if it's gonna make it too loud.
Cheers guys.
Cheers guys.
Probably won't make a difference in noise.
Cheers guys gonna go to my local exhaust shop tomorrow to get a price, what size piping do use suggest? 2.25" or 2.5" for the v6 only other mods I'm gonna do is cold air intake.
Cheers Tom.
Cold air intakes are a waste of time and money. Edited by 1badkiwi
      Po299
    2. 0
      Boot Dimensions?
    3. 1
      2007 - Floor mat
    4. 0
      2007 - floor mats
    5. 6
      Front parking sensors
    6. 0
      Cruise Control Not Engaging
    7. 0
      Head Unit with Apple CarPlay
    8. 4
    9. 1
      2007 - Floor mat
