I dont know jack when it comes to rims and all that camber mumbo jumbo so my question to you lads is, Will the rims from my car fit straight onto my mums ascent* with out any problems??
*one of these bad boys
As long as they are 4 x 100 stud pattern, they'll fit. those look like 14" wheels. you'll have to make sure you are running the same rolling radius to ensure your speedo is still accurate'ish.
Yeah, the rims will fit perfectly but the tyres will cause a larger rolling diameter...
When your speedo reads 60, you'll actually be doing around 66 - 70...
