Interior Light
Zeus
btw...poke the screw driver on the passenger side side of the cover ...
there should be a small gap there...
ps... when removing the bulb done use a metalic object to pry it off the metal contact...
if ur not careful ull make contact with the other terminal...
even with the light switch in the off position there is still enough residual current to blow the fuse like i did last week!
if ur adventerous look into jaycar... for around $30 they have a compact mini 12 led panel (aka smd's) that comes with universal adapter bases.. fits in the roof light and gives a super bright white light... looks nice and wont flat ur battery
the boot light and glove box light can also be changed to give the old girl a new look... but then $90 could probably be spent else where... :rolleyes:
    2. 16
      2000 Corolla Ascent - clock.
      ST205 for sale
      Rukus for sale
    6. 8
      CH-R sudden engine failure
      2Door 1975 KE30 Corolla 4Sale
      Hi from Wagga
