1994 Tarago/Previa
megsy
Today I had an overheating problem . checked water level this morning because it overheated the other day in hot weather towing a caravan. :angry: (It only travelled five km.)
Anyway I got about 10km down the road and the temperture gauge began rising. I pulled over to the side of the road and allowed it to cool. took off again and it rose to red , pulled over again for about 5 minutes and it cooled . Turned car around to come home. I basically bunny hopped it all the way home. Had to pull over five times the car went for about 1 - 3 km's before having to pull over.
checked manual . but nothing in it seems to suggest anything serious . In fact it doesn't say much at all.
-air con wasn't switched on at any time
- all oil and filters are fine...........although oil under the bonnet was at low but i have put more in . Oil in engine (dipstick ) was fine.
-checked water after i got home and no problem.......it was a little brown so I flushed it.
- no spots under car indicating any leaks.
does anyone have an answer?........ I'd prefer not to be stranded in the heat tommorow :unsure:
Ok bit more engine oil in it and it went 25 km's before heating up to 2mm off the red. NOT GOOD
Anyone have any ideas before i take the *** damn engine apart?
cause i'm gunna!!!! I have the tools and I'm threatening to use them !!!!!!! :spiteful:
      Invisible Instruments fix
      Can I use USB hub to get more USP ports?
      Rav4 smart key keyless entry
    9. 13
      Starter motor issues
