damo's ae82 twinky
damo101
test fitting the 2 chassis mounts.i knew the timing cover side would fit but we were just testing to see what needed to be done about the gearbox side.we ended up fitting the original C52 gearbox mount to it.only 1 hole doesnt line up on the bottome half of the bracket.
i was going to paint the engine bay myself but i went to ask the guys at the panel shop next door the best way to go about and they said they would do it for $50.SOLD!! all i had to do was mask up, using there stuff to.so Monday i will get it back ready to go.
Edited by damo101
  • Replies 114
  • Created
  • Last Reply
Top Posters In This Topic
damn..the boys at Romano's must love u!hahaa
Edited by GReddy_ES
yeah i know ay, i was expecting it to be at least $150 but i guess it doesn't take them long when i was the one who masked it all up for them.all they have to do is mix it up and spray it.i was happy with how it turned out after we cleaned it but i guess while its all out may aswell get it done..
thanks guys, yeah its my custom GFB I/C :D
well the motor should be sitting in the bay by this Friday.i've been waiting and waiting for near on 6 weeks for smaller supercharger pulley but i've given up on the guy..so i'll just use the factory one for now..i would like to think it will be about a month and a half away buy depending on what pops up during the dash conversion it may be a bit longer..
putting the selector cables and clutch line etc. back on
i notice that little square piece was worn down one side so it may be causing sloppy shifter feel, i just turned it around to anew side.
wiring, i hate it.
getting the supercharger pulley back on in the car.wasnt as bad as i thought.
got all the accessories bolted up, front of the engine is pretty much done.
both the looms.yuck.
still need to make up a crossmember for it..will be doing that during the week sometime.found a mechanical speedo sensor aswell.
  • 3 months later...
what car is that centre console out of
cheers ben
its just the stock ae82 one.
these pics were from the end of last year:
finished re looming it, put the stock ae82 shifter assembly in, put the accelerator cable in, put the brake master cylinder back on and put the thermostat housing assembly in..
    6. 21
    7. 21
    8. 21
