Which aftermarket HID for Aurion?
Hyo
I need some help for my HID homework.
Thinking about getting one from the eBay, but which one?
I found Bosch one, but not very sure whether they are genuine or not (I couldn't get it linked. Generation VII, 191 dollars).
Would you recommend one for me?
Thanks a lot,
Edited by Hyo
Thanks a lot,
This is a OEM genuine one :P but it only accepts D2S bulbs
The only site i know that sells rebased genuine ballasts is xenondepot - btw they are expensive..
http://www.xenondepot.com/
just buy any brand, doesnt really matters. The headlight on aurion is designed for HID, so there isnt much(or should i say "no") glare.
Should only pay around $150-$180
I don't agree with that^ :idea:
The HID headlight has different lens and projectors. Therefore putting a HID bulb inside a halogen projector = glare...
Just because it is projector headlights does not mean a HID should fit in there.. (but then a lot of ppl do!! annoys ppl on the road!!)
+1
maybe i m lucky when choosing then..
i m just talking about case for Aurion, not other cars like camry
05, which i know the glare is just scary..
well certain cars do have more glare than others - yours seem to be on the better side (but you can still see some glare spots above the cutoff point)
and also the hot spots..
Just thinking logically, a halogen bulb were designed to fit in your headlight projector- and now you put in a rebased HID bulb, the optics of it is different so obviously its not used as it is intended....but there's nothing stopping you :)
Just FYI, This is a real HID
I also saw the bosch HID on ebay but then didnt know if it was legit or not so i didn't end up buying it.
Because usually german made HID would cost you 300+ so dont know why that one is so cheap.
I ended up buying a Kit called "Alpha HID"
i bought some MTEC 4750K bulbs that i have no longer use for since i got HID now
so if anyone wants to grab them off me for some $
just msg me or something =) the package has been opened just to see if it fits on the car, but hasnt been used.
Edited by ZZR88
I finally got the 4300K MTEC hid kit. :rolleyes:
I'm know that aftermarket HID is illegal but couldn't resist the 'brightness!'
I think it has a little bit of glare and hot spot. So thinking about lowering the angle..
Anyway, it looks good!
congrats
any pics?? from inside and outside the car?
    2. 0
    3. 1
      Need Advice please
    4. 2
    5. 2
    6. 10
      Engine Immobiliser
    7. 1
      Hello Toyota Club AU
      Fuse boxes info
    10. 0
