Aurion Fuel Tank Capacity & Low Fuel Indicator
Rav4 smart key keyless entry
Hey mate, are you sure that's an option for the vehicle? Some models have various set ups. I've had Toyotas that will auto unlock, but not auto lock. I haven't had the chance to work on that one yet thanks to the issues Toyota is having with their keys... I'd like to know if you figure it out! Dave - An interested locky... https://www.keysocallaghan.com.au -
Have got a 2010 n70 Toyota hilux and looking to bump the front up to a 2.5inch lift. Other than the upper control arms, seeing what else needs for geometry to be stable. cheers -
I'm not too sure about "old fluid to make shifts". Personally at 160,000 kms I would change oil and FILTER. Clean oil will help your tranmission shifts better and remove worned metals inside, metal shavings can prevent solenoids from working properly. This is preventative maintenance. -
13
Starter motor issues
We sell the starter motor to suit the 5S-FE on our website carusoautoparts.com.au - here is the direct link below: https://www.carusoautoparts.com.au/store-2/p/jas-starter-motor-snb034-to-suit-toyota-camry-sxv20r-1997-02-5s-fe-20l-petrol?rq=Snb034 -
Just purchased a 2024 Rogue, love it generally however. Whichever mental giant decided silver was a good colour to have on a vehicle dash needs to go stare directly into the sun for an hour or so. 🙂 The reflection projected onto the windscreen and the glare that comes off them is very distracting… Anyhow… anyone know: 1. How to get the speaker grills off the dash wart speakers? 2. If there are matt black speaker grills available from somewhere? 3. What could be done to convert these to 100% matt black that will look professional and be durable enough to sit on the dash, exposed to the sun. Thanks in advance! -
Noob here! I've got a modern Hilux with a Mountain Top Roll Cover on the back tray: https://mountaintop.com.au/products/mtr-roll-cover-to90-91?_pos=5&_sid=838d083ad&_ss=r I'd like to get a tub rack on the back like this on the cheap: https://www.4wdsupacentre.com.au/kings-universal-ute-tub-rack-3mm-zinc-powdercoated-steel-adjustable-height-width-easy-diy-install.html?gad_source=1&gclid=CjwKCAjwydSzBhBOEiwAj0XN4PZO8tXD7-IdCLidg4-yQks3Pa472OAGpoM-U650arpHAT5UlI4mJRoCHKsQAvD_BwE but I'm struggling to understand what will fit with the mountain top roll cover. Could anyone help me out? I'd like to get a rooftop tent on the rack but from what I'm seeing mountaintop don't have a solution to this. -
Does anyone know the cost of this repair? I’m pretty sure mine is outside the warranty period. I’ll book it in anyway, just curious is all. -
Do a Google search https://www.google.com/search?client=firefox-b-d&q=T-SB-160-18 Then download the file and read it. If applicable as a warranty claim, the transaxle will be replaced. T-SB-0160-18 - Transaxle Whine Noise, Harsh Shift, MIL ON, or Reduced Power .pdf The assessment cost relates to Steps 1-3 to confirm that this service bulletin and warranty claim is applicable.
