Adjusting HID's
Its the glare not the brightnes.
At night park on a flat surface with a wall around 2m away.
Adjust both evenly (If they haven't been adjusted before).
From around 2m you wouldn't want it much higher then 75cm
once this is adjusted, move your car back around 10-15m, and have a look at the spread then.
The other idea is to turn the drivers side headlight towards the left. With the stock headlights its pointing slightly to the right.
Keep the left one where it is in regards to left/right as this will become perfect when driving in the inside lane, as it lights the entire footpath up.
Best flat surface is a car park BTW
Just park ur car infront of a wall..n then just tilt them lower..this way it will not glare the on comin traffic..just keep lowerin em till ure happy with it..dont lower it all the way n stuff cos u wont be able to c xD even though with hids on xD.. yeah..just do it low enough..n u should be fine..good visibility and doesnt glare on comin traffic..win win :D
      Seat change
      1993 Corolla Seca CSI limited
      Corolla Seca For Sale
    5. 4
      2013 camry for sale
      Rav4 smart key keyless entry
