HI When I put the car in reverse the drivers mirror moved down corrctly than stuck in that position when I engaged drive. has anyone had the same problem I phoned Toyota who seemed to feel this was not a warranty issue..in a car that is 6 months old!!! The passenger mirror in fine
Posted (edited)
... I phoned Toyota who seemed to feel this was not a warranty issue..in a car that is 6 months old!!! ...
A bit scary - they must fix it if not from an accident
BH
Edited by BanHien
Hi, This is a common fault - keep going back to your dealer !!!
Thanks I will press them it is amazing how they always make out that you are the only one with this problem!!
i test drove a presara tonite and was trying to activate the lowering of the mirror but failed.
is it automatic?
is it automatic?
Hi Freddo,
The Lowering of the Mirrors when in reverse only occurs when the Mirror Selector switch ( Used when adjusting the positon of mirrors )
is NOT in the center position.
You can leave it in the center position when you do not require the mirrors to lower.
Regards
Derek.
is it automatic?
Sort of . . . you need to have the mirror adjustment control switch set to either left or right mirror. If it is in the center (i.e. no adjusting) then the mirrors do not lower on reverse.
I normally have it set not to lower, as I find it a bit distracting, and I generally switch on for reverse parking only.
Posted (edited)
i guess i'll have to test drive it again then. thank for the info.
its a good feature to have if u have some nice aftermarket rims.
Edited by Freddo
    2. 5
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
