[DIY] Replace your Shifter Bushings (2ZZGE 6SPD)
  • 4 months later...
  • Replies 131
  • Created
  • Last Reply
Top Posters In This Topic
hey guys anyone here still selling kits? OP appears to have gone on holiday :(
i read through all the posts but still not sure what bearings/washers needed for a 1zz since the vertical ones cant be changed. someone help a noob out here pls
he hasnt been on the forums for ages. he just hasnt been bothered to come online. just get the skateboard bearings yourself i think i posted a picture above somewhere u get from laverton. then get a few washers to cover the gaps and some rubber o rings and ur set!
  • 5 months later...
Forgot about this! Okay so just before I purchase the items, can anyone tell me if this is right? According to Evo7, the 1zz horizontal bushing can be replaced same as the 2zz. But the vertical requires a larger OD bearing roughly 26mm.
Would these work for vertical bushing you think? Or is it the wrong measurements for width and ID
http://www.ebay.com.au/itm/6000-ZZ-10mm-id-x-26mm-od-x-8mm-wide-Metal-Shielded-deep-groove-ball-bearings-/360464535544#ht_770wt_699
and these for the horizontal. 608Z
http://www.ebay.com.au/itm/NEW-608Z-bearing-double-metal-shields-NSK-JAPAN-top-Quality-Skateboards-2-PK-/190752776032?pt=AU_Skating&hash=item2c69c05f60&_uhb=1#ht_500wt_716
Then was gonna shove in some rubber O-rings as I have them lying around instead of metal washers, as long as it's snug it's ok?
http://www.gulfrubber.com/parts/o'rings.jpg
Edited by handsome
  • 1 year later...
Hi all, I came across this thread today and due to all the positive feedback I decided to do this mod however I found it a little difficult without any pictures.
Does anybody have any pictures available?
  • 6 months later...
