Alternative 19" tyres for KX-S and Grande Kluger
holmesie
I'm not needing tyres yet, but was a little concerned to see how few tyres are available in 245/55R19 with the correct load and speed rating. I know in NSW it's allowable to have a lower speed rated tyre fitted, but it must have the same or higher load rating.
In slightly larger 255/55R19 sizing there are a few more offerings, such as;
Pirelli Scorpion Zero
Pirelli Scorpion ATR
Yokohama Advan ST v802
BFGoodrich G-Force T/A kdw
None of these sound cheap <_<
I'm thinking 255/55's might make a slight improvement on the speedo error too. Anyone got any thoughts, or experience with 19" tyres on their Kluger?
  • Replies 100
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Cayenne & Touareg run on Michelin Latitude Sport or Latitude Tour HP I think - only the Tour comes in a suitable size 255/55R19, but not the Sport for some reason :(
I found this excellent info site with some great info on wheels and tyres:
http://www.carbibles.com/tyre_bible_pg2.html
THere is a great little java calculator which tells you how much speedo error is introduced with a different tyre size.
Also another calculator to check how different size tyres can be used for our rim size (7.5 x 19)
we should be able to fit a 275/55 on the 19" rim and that profile will reduce speedo error by 5 km/h
Where did you find a tyre with a lower speed rating. The original tyres are only rated to 180km/h; that is why they quote that as the maximum speed.
I haven't found one with a lower speed rating, but if there was one available in the correct size I would not be worried about fitting it - we pay a lot of money for speed rated tyres that never got to see their maximum speed in Australia :(
Thats why I still drive a Subaru mate they need them!
For sure mate, I'll keep posting up any info I find - unfortunately I've found on any new car I have bought, the stock tyres don't give good mileage (the sceptic in me says there's some conspiracy there) :lol:
Found on the bridgestone website that this tyre can have an alternate, which is the Dueler HP Sport, a sportier tyre apparently, which is 265/50/19. Anyone know what the price of these are? They are speed rated Y which is 300ks! lol, the originals can only go 180!
Anyone in the know?
  • 5 weeks later...
What speedo errors are there?
Basically if the needle is showing 100, you're really only travelling around 93km/hr (measured by GPS) <_<
There is a thread or two about it somewhere. EDIT: found one here
I just got the car 10 days ago. No wonder people keep tailgating me and over taking me............ :unsure:
Yeah, it's a trap if you don't know about it - the odometer apparently reads pretty close to spot-on, but not the speedo - go figure!!!
GPS Doesn't lie!
Let me know how you go with the Tyre search Andrew.
By the way I cant even log on tho the other forum site any more...new site was the worst move ever!
Thanks Andrew.
Just a bit off topic if you don't mind. I would like to get some sort of GPS to verify the actually travelling speed. What sort of GPS do I need for that? Is GPS same thing as those Sat Nav that fixed to the windscreen? Would it tell you the travelling speed?
Thanks.
      Upgrade from 2012 to 2023
    5. 3
      Towbars
    6. 5
    7. 2
      ASV50 Camry Head Unit Options
    9. 2
