I fitted the genuine tow bar and wiring harness to my 2006 RAV. Unfortunately there is a fault somewhere. There are no "signals" coming out of the trailer base when I put on the car brake, park, flickers etc.
I traced the problem and found that there is power (obviously when the brake, park or flickers are activated) at the small black "junction box" which is part of the new harness and is mounted inside the cavity at the left hand very rear of the vehicle. But there is no power coming out of it. Maybe it is faulty?
I also notice there is a blue wire coming out of the harness just there and wonder if I have "missed" connecting it to something or is it just a "spare".
Any body got any ideas to help. We were supposed to be towing our trailer on holiday today. Whoopsie!!!!!
if you've wired everything up correctly, it could be possible the wiring harness is for the wrong model rav...
check the fitting kit for which model it's for?
and i think the spare wire is for electric braking kits
Blue wire never gets connected when I install tow bars, never even read what it's for lol...
Check all your wire colours match up, check all the wires line up within the plugs and also make sure you've connected the plugs the right way around...
If your rear lights work on the car, they should work on the trailer...
Posted (edited)
thankyou for the help guys.
The black "module" or "junction box" I talked about earlier has only one set of wires coming out which go exclusively to the trailer plug. It seems to me the module is either not working or is not being activated or whatever from elsewhere.
Edited by elix2
      GVM UPGRADE FOR LC300 SERIES GR-SPORT
    2. 12
      Brake issues
    3. 12
      Brake issues
    4. 0
      Wanted Corolla Sportivo standard springs
    5. 12
      Brake issues
    6. 0
      Opinions please: Questionable replacement 2GR-FE 3.5l V6.
    7. 0
      Imported Toyota Prius hybrid - Plug in 2017
    8. 3
      Yaris Cross Space Saver
      horne
