changing steering wheel
I'm pretty sure you have at least a drivers side airbag right? When that is the case, swapping your steering wheel will completely render your airbag useless as it will no longer be there. Sure you can fit the steering wheel, but you SRS warning light isn't going to disappear.
Edit: Was going to say what micky_tee said below (as I have heard this numerous times), but couldn't locate a document to support my statement.
It is illegal to fit a non-airbag steering wheel to a vehicle factory fitted with an airbag steering wheel...
if you get caught....
And if you get in an accident and they find that there is no airbag...
      Aftermarket Air Intake
      Heater problems
      Entertainment Unit Upgrade
      Seat change
      1993 Corolla Seca CSI limited
      Corolla Seca For Sale
      High mileage camry
