error in stock cd player ?
For some reason, i keep getting these error01 messages coming up when i try to play some cd's - and because of it, i have to either skip to the next cd and then skip back or turn off the cd player. Is it because my cd's are all burnt ?, ive never had this problem before though only recently which sucks
If the problem only occurred recently and your player had no issue playing the discs before, provided they are not scratched badly, try getting a head cleaner disc. My CD/DVD drive on my head unit was playing up only just yesterday. Since I rarely swap discs on my player, I ruled out a scratched disc issue, so I put a head cleaner disc in and 1 minute later it was playing my disc again.
I had the same problem, it would occasionally play burnt cd's and then sometimes it would only play random tracks, Original CD's worked perfect. I tried everything, but still the same problem, So i just replaced it with a Eclipse, headunit.
Fujitsu Ten make awesome quality headunits...
We change 10 every week...
If it's in warranty get a new one...
If it's out of warranty, go aftermarket...
soo hard to find any aftermarket units that just look stock and black
      Towbars
    2. 5
      ASV50 Camry Head Unit Options
    5. 2
    8. 14
    9. 2
      Hi from Wagga
