Advertising WRX Body Kits On Corolla Forums ???
Front Cameras
Can Camera's with Sensors be retrofitted in place of the sensors? -
51
Not ideal where you are but I would ry a couple of things: Either disconnect the batteries (both) and leave for a good 10 mins - enough time for all electrics to discharge.. Another one which worked for me was to disconnect the ECU - big plug on the passenger side firewall. Same thing, allow for electrics/electronics to discharge. Not practical for you at this stage but if you can get a Scangauge. This will allow you to clear the codes. Car has gone in limp mode. I had this problem several times whilst towing a caravan due to a performance chip which would cause a limp mode. No more as I have had the ECU remapped. -
51
Hi I have a 2011 landcruiser GXL I am experiencing this issue right now & stuck in Cocklebiddy. Can anyone assist please ? -
1kzte throttle body
Hi Simon, You could try this mob. Genuine Japanese Car Part Imports - Amayama I have found that they seem to have everything, and their prices are good. Herb -
Aftermarket parking sensor
4
Head Unit with Apple CarPlay
8
- transmission stutter
(and 1 more)
Tagged with:
I immediately thought of sound deadener material which is available from JayCar as a potential solution. https://www.jaycar.com.au/combination-butyl-foam-super-sound-deadener/p/AX3689- 1
