hmm has anyone ever tried it??
what methods would you use, left foot break and accelerate
e-brake sure wouldnt work for the aurion
Depending on the road temp, condition, and tire condition, the Aurion can smoke up the tires pretty good.
First important step, turn off traction control and then hold your foot on the brake with the parking brake off.
Second step, turn your wheels at a slight angle. This will prevent axle tramp because the Aurion doesn't have quite enough torque to break traction quickly and cleanly.
Third step, take your foot off the brake and then quickly floor the accelerator. As you move forward, try to prevent your wheels going in a straight line for more than a second. For some reason, the Aurion doesn't like this and will start to axle tramp.
Alternatively if you want to do on on the spot, you can leave your parking brake on or once it is on full, push it in a little to un-latch it so that when you want to start moving, you can release it easily. Just remember, same rule applies for keeping the wheels at an angle.
my atx dont have t/c button?
I wish mine had one too.
The only way to turn traction control off on the Aurion is to follow this sequence (in under about 30 seconds):
1. Make sure the car is in Park and the parking brake is disengaged before you start the car.
2. Start the engine.
3. Engage the parking brake.
4. Fully depress the brake pedal and then release.
5. Fully depress the brake pedal and then release.
6. Disengage the parking brake.
7. Fully depress and hold down the brake pedal.
8. Engage the parking brake, then disengage it (while holding down the brake pedal).
9. Engage the parking brake, then disengage it (while holding down the brake pedal).
10. Release the brake pedal.
11. Engage the parking brake.
12. Fully depress the brake pedal and then release.
13. Fully depress the brake pedal and then release.
I've done this quite a few times already, I think I have it in my head now.
My take is, why bother wrecking such a beautiful piece of car by doing burnouts?
Don't worry. It's a Toyota. It'll be fine.
how do you turn back on
You need to turn the car off then back on again. It will always turn back on every time you do that.
      Tyre Sale Specials
      overheated engine
    4. 62
      Tyre Sale Specials
    8. 10
      Remote start
