Hey i was wondering.
tiet
hey i was wondering, i drive a 2003 corolla sportivo, my driver door and rear right door are damaged, is it possitble to get a 2003 corolla (base or lower model) and put my inside trims on those and install it on my car?
keep your trim, i dont know the state of the window bracket and internals so you may be able to re use them also.
but im 99% certain that the door skin (outer) is the same
sh*t Anthony how did that happen???
if you can get them from a south african made rolla then it should be ok
You might have trouble mounting the motor for the electric windows if it's not South African.
Is the silver a different shade too?
Gav.
yeah might need to mix and match paints if thats so :(
I think I read a post by SuperDave a long time ago, that the door handles between the SA and JP-built models are at slightly different positions from each other. So that might be an issue. Try to find a door from an SA-built Corolla.
      1kzte throttle body
    4. 3
    5. 5
    6. 5
    7. 8
      PZQ60-00525 Issue
    10. 3
      Head Unit with Apple CarPlay
