ZRE Bonnet Dampers & Custom TailLights
Do a Google search https://www.google.com/search?client=firefox-b-d&q=T-SB-160-18 Then download the file and read it. If applicable as a warranty claim, the transaxle will be replaced. T-SB-0160-18 - Transaxle Whine Noise, Harsh Shift, MIL ON, or Reduced Power .pdf The assessment cost relates to Steps 1-3 to confirm that this service bulletin and warranty claim is applicable. -
How did you go with this problem? Mine is doing something similar so I’m curious. Can I ask where you found the service bulletin? -
Adding more spotlights
I have put on a Toyota light bar on our Hilux, can I cut into the power wire to support 2 x 9 inch kings led spotlights or is that to much draw? or do I setup the supplied wire loom and hook into the high beam switch wire on light bar to switch a second relay? cheers -
GR sport tailgate seal
hey guys, new to the club, picked up a 24 GR Sport yesterday. Has a gap in tailgate and wanted to seal the canopy from dust. Does the Rouge seal work? Have tried Grunt but they don’t do one yet. -
Fuel light vs remaining range
Got a new rav4 hybrid cruiser and still 'testing'. This week tried to see how far we could go on a tank before the fuel light comes on. For the entire tank, actual kms driven + remaining range remained around 900kms. With about 790kms driven and remaining range on about 125kms, the fuel light came on but then remaining range suddenly dropped to just 25kms. This was really baffling. When we filled up to auto-stop, we added 43 litres, so I would imagine the 125kms range we had just before the light came on was more accurate. Just wondering if anyone has an explanation for the sudden drop in range? -
Clock on multifunction device not displaying
Hi Andrew, did you find a solution to why your clock is blank but options are greyed out? My 300 Landcruiser has just done the same thing… 🙈 -
Bluetooth stopped working
Did you change your phone or had a software upgrade on your phone? -
4
Android auto not working Toyota corolla ascent sport hybrid
From MEMORY this car doesn't have wireless Android Auto. You might be best off speaking to either Toyota Sales Dept or Service Dept because their MAY be a cable that you can buy (so have would WIRED android auto). But again you would be best to go to your nearest Toyota dealer and speak direct to them in person. I hope that this helps. -
Hi, I am new to this forum and i hope i can get some help. The mechanic said he can't tell me how it's done. I will keep this in mind before i take a car there again. Interestingly, the manual only refers to the front LH side Replacement of the Front RH park light Corolla 2006, but not the RH side. Could anyone alight me on this? Thank you. -
5
Oil leak help!
Did anyone figure this out, my stivo is doing same thing.
