Soon to be sportivo owner
Tyre Sale Specials
- tyre specials
(and 1 more)
Tagged with:
overheated engine
62
Tyre Sale Specials
- tyre specials
(and 1 more)
Tagged with:
10
Android auto
Does any one know if the trd sportivo suspension for the 2017 facelift corolla fielder fits the 2013 prefacelift version? Is the chassis the same? Thanks for the help.
