Progress Rear Sway Bar
Hey guys has anyone tried this bar, its made for the 03-07 corolla in the U.S. Do you think it will be a good upgrade for the runx/sportivo?
http://newsite.monkeywrenchracing.com/prod...roducts_id=1205
Would be handy if they had the diameter of the bar. Why not just get the Whiteline, TRD, Cusco, etc ones?
Get a known brand which has proven performance,whiteline bar is 22mm which i think is perfect i dont get any oversteer very neutral, 24mm would definitely give you oversteer.
Edited by chef
Its not as simple as whack on the rear swaybar and off you go, unless the company has proven results with use of factory front sway, you'll find your car's handling compromised. You need to match it with the "correct" front swaybar :)
      What to say!
      Just joined
    3. 7
      2ZR Turbo
      Just joined
      280,000 K Maintenance
      How rare is the 2002 camry v6 manual sportivo
      Camry 2007 Electrical Question
    8. 18
      Just purchased a 1996 Corolla AE102R CSX
      Tried everything won't run right
      Newbie
