CUSCO'S Are Finally In
MAP81
can you please measure it from centre hub to fender?
I am at around 30-31cm atm.
Just did a rough measurement for you Danz, it is about 29-30cm, but you could possibly go even lower if you were to adjust the spring seats aswell....
can i ask how much they were for the set as the coil overs i have in mind at the moment are 1850$ (36 way damper+ height)
vs
new springs and dampers at approx 1500 (only 10 way damper but lower ride height)
who is the person here that does the cheap koni' again ?
As for the price of new ones I wouldnt be able to tell you.... I got these from the yahoo auctions in Japan :D .... But stockvvti or Danz should be able to tell you as I believe stokvvti has just purchased the Zero 2's (next step up from mine) and I know Danz has been getting prices form everyone and anyone for all sorts of coilovers...
May aswell grab coilover. D2 or Cusco, is your choice. Speak to stockvvti for Cusco, he'll help you out ;) Both are montube design and comes with camber plates. you may not need a strut bar or sway bar ever again once you have this stiff meisters.
But if u buy koni+springs+sways+strut = the price for coilover anyway
and nothing like a 4 inches of drop
If I have the Cusco, hell yes!
Well yeah if drive through bad holes. But no, I hardly rub at all. I can have full passengers, total of 5 that is, and the car is fine fine fine ;) Besides, I remember the roads so I know which area I should be really careful at. I didn't roll the guard at all.
