hi guys,
i was wondering if i could possibly move the 12volt power source to the glove box (the one im talking about is under the satnav scree in front of gear select) because when im on the go i would be charging my phone and id put it on the glovebox anyway why im saying this is so i dont have to look at in while im driving haha and so theres no leads running all over the interior
any ideas???
i was thinking more along the lines of moving it completely and having it come through the side of the glovebox or would that be more of a pain the just rewiring it
1) The socket itself is moulded into the ashtray compartment and removing it will make it become a bit of a mess.
2) You will still need to run separate wires for it because the current ones for it are loomed with all the other wires for various other things and it would be easier to run new cable instead of removing all the cable loom and re-running the existing wiring.
ok thanks again your way is easier i thought i would have been a case of just undoing a few screws holding the socket moving a drilling but no sounds of it ill be doing it the way youve said thanks again
      Remote start
    2. 1
    3. 0
    4. 9
      Android auto
    5. 9
      Android auto
    6. 1
      Turboed Corolla Overbuilt?
    7. 3
    8. 3
