Tyre problems
Wulfkind
Hi Guys,
Long time no post, I know. Been extremely busy with that horrible thing called life...
Anyhow, heres the issue. 12 months ago I bought a set of Pirelli Dragons for my Aurion, loved them entirely fore the first 8 months or so and then lost my trust in them when the drivers side front developed blistering in the sidewall. I replaced that tyre and moved it to the back, about a month later, travelling down the F3 I had just aired up (they were down on air about 1psi, but it was a cold day too) the tyres at the twin servos and checked them over (used my own pressure guage too), left the servo and hit 110 on the freeway, about 5 minutes later the drivers front (same one again!) decided it didn't want its inner sidewall anymore... I managed to pull the car over safely (it was amazingly, still smooth to drive)
At that time, I replaced the two front tyres with a pair of cheapo bridgestones (couldn't afford anything fancy, sadly), now about a week ago I had the same issue again, the inner sidewall seperated from the tyre at 110 on the highway. I'm not sure if this is just coicidence, but I'm a little concerned that the tyre on the drivers front has always been the one experiencing these failures, I don't drive like a lunatic, in fact, this last 5 months or so has been mostly country driving (avoiding potholes etc)
Now I can rule out an alignment issue, as the car has been regularly aligned as well as aligned each time I replaced tyres, the tyres have also been fitted by different tyre stores and each inspect the rim each time (different rims involved in all incidents though)
Could this still be a driving style issue? bad luck? mechanical issue that hasn't been picked up? I really don't feel safe driving the aurion at highway speeds at the moment so any advice would be appreciated.
Edited by Wulfkind
Hi Guys,
At that time, I replaced the two front tyres with a pair of cheapo bridgestones (couldn't afford anything fancy, sadly), now about a week ago I had the same issue again, the inner sidewall seperated from the tyre at 110 on the highway. I'm not sure if this is just coincidence, but I'm a little concerned that the tyre on the drivers front has always been the one experiencing these failures, I don't drive like a lunatic, in fact, this last 5 months or so has been mostly country driving (avoiding potholes etc)
Im in a similar boat to you.My front passenger tyre always drops about 5psi compared to the rest when i check my tyres.Ive rotated them twice and it only seem like my front passenger tyre is the one loosing pressure.It Doesnt bother me as much as i check them every second refill at the servo.Cant figure it out.
I run 32 psi (235/40R18's) they are correctly load rated, as I said, I only have problems with that one corner.
32psi is too low for an ultra low profile tyre. You should be using 40+psi for that size. This explains why you have sidewall problems with your tyres.
Edited by A Buff Hamster
Actually, about 35 PSI would be a good starting point. I wouldn't be going all the way up to 40 PSI unless it was just for doing a long highway drive or if you are going on the track etc.
But yeah, 32 PSI is a little on the low side. That's what created blisters in the sidewalls of my last pair of low profile tires.
      Seat change
      1993 Corolla Seca CSI limited
      Corolla Seca For Sale
    5. 4
      2013 camry for sale
      Rav4 smart key keyless entry
