My Red Rocket Rolla
Dj Watt
sup all thought i would share my little rolla around. been getting alot of work done to it coz of its age and all.
engine: 4a-fc
exhaust: 2.25ich cat back system with drift pipes on the end
mods:
Heat Wrapped air intake
Lowered with bridgestone potenzer struts and king springs
Full sound system
i will have some video up soon
post-14232-0-14724400-1289806547_thumb.jpost-14232-0-84847000-1289806530_thumb.jpost-14232-0-14724400-1289806547_thumb.jpost-14232-0-78244900-1289806468_thumb.jpost-14232-0-54988700-1289806358_thumb.jpost-14232-0-20079400-1289806398_thumb.jpost-14232-0-48500100-1289806407_thumb.j
post-14232-0-54844500-1289806385_thumb.j
post-14232-0-90549100-1289806434_thumb.j
post-14232-0-59972200-1289806446_thumb.j
post-14232-0-01866500-1289806505_thumb.j
post-14232-0-64337800-1289806517_thumb.j
A good little base to start from mate where do you think you will go with the car as far as changes go? xoxo
Yer i dont know hey lol but i am open for any advice :D
atm i have plans to work on the air intake and put a 36mm double barrel webber on it full custom exhaust. maybe sports cams. anything :D
but as i said i am open for suggestions
I like the colour and the car looks in good nic, well done.
Can I suggest a change in wheels and no engine mods, you ain't going nowhere in a hurry with that motor
whitestivo
hahaha yer i kno but not bad for getting the car for 3K lol but yer it is a challenge i will take.
i like its weight to power but it ****ty in the power. I am slowly working on that.
Update for all.
Got a bit of work on as i have the following to change
Machine head
Gafite head gasket
new head bolt set
Full Tappit cover kit
both grafite manifold kits
new conrod sleeves
new rings
shall feel the change and will have some pics up when the kits roll in.
shall have some more pics after the old head is off and the new one going on. it will be interesting to find out what the top of the pistons will be like when i pull them out
      help with clutch
    5. 3
      newbie from Queensland
      High mileage camry
      1981 Hiace ignition upgrade
    8. 2
    9. 1
