Which turbo? help
Mealsy
hey guys
imwanting to start my car upgrades and im thinking a turbo
can anyone help me get started eg.
what turbo can i use?
what will i need to get it going?
can anyone tell me where i can get the stuff do it?
im not very mechanically minded so any help at all will help
thanks guys i look forward to hearing ur suggestions
mealsy
depending on whether u want to cut corners or do it properly it can be cheap as chips or nice and expensive
mate pretty simply put have a read in the ZZE FAQ pinned to the top of the forum.
http://au.toyotaownersclub.com/forums/index.php?showtopic=24512
look under the Forced Induction section in the first post
First things first... whats your total budget and what model Corolla you got...
its 02 corrola levin
not sure on the budget, just want to get an idea of what i have to do and wat it will cost
It'll be cheaper for you to sell and buy a Sportivo then if you want more power. If you want turbo, buy a turbo car or be prepared to spend big money!
Welcome aboard....
In all honesty, i dont see you getting Turbo in your car..
oh really why is that?
can it not happen? not enough room?
what do u suggest ronny?
It can definitely be done. If done properly it may set you back 5K-15K. (Depending on what you do.)
What has been done to the car so far? How much KW does the car have now? How much KW do you want?
No Budget = No Turbo :)
If you're not mechanically minded it will cost you between 12-25K to turbo your corolla so it makes decent power. For it to be reliable you'll be looking closer to the 20K end of the scale.
You can look at Bill's car for the top end of the scale, or Pippy's car for the budget end of the scale.
Pippy's car was initially tuned for 9psi with a WRX MY08 TD04L and it made 140kw atw, I've now setup gear-based boost control on it and it runs 14psi in higher gears but I haven't had it redyno'd to see what power it's making now. The car was previously running a TRD supercharger with water/meth injection making 117kw atw on 10psi.
It's now done 30,000km on the turbo setup, and 20,000 before that was with the charger, over 100,000km on the stock 1zzfe long motor. It hasn't had any issues with the engine etc in that time.
Rough costs & Specs are basically:
-Custom steam-pipe merge-collector turbo manifold with ceramic coating $800
-Secondhand very low km MY08 TD04L WRX turbo $300
-Custom 2.5" exhaust from turbo back with metalcat, magnaflow barrel center muffler and large stainless oval rear muffler $1200
-xr6 turbo garrett intercooler $150
-Alloy intake & intercooler pipework, silicone joiners with T-bolt clamps, Bosch plumb-back BOV and 6" base K&N Filter $1000
-Exedy extra HD Clutch supply and fit $800
-ST215 525cc injectors and plugs $200 secondhand or $560 new
-Vipec V44 ECU with 3bar map sensor and plug'n'play harness $2000 not including dyno time
-Oil Feed line/fittings, turbo water lines and oil drain line/fittings $300
-Sump modification for oil drain $200
-Custom inlet plenum $800 (not really required)
-Walbro in-tank fuel pump + fitting $200
-Engine oil cooler $600
That's close enough to $9K and lists most of the major stuff. In reality I'd expect a workshop to charge $12-15K for a comparible setup. We also put in a LSD 6-speed and it's matching driveshafts when the TRD charger was initially installed.
http://www.purcellperformance.com/dyno/1zzfte_dyno.jpg
http://www.purcellperformance.com/1zz/ZZE122_Bay.jpg
http://www.purcellperformance.com/1zz/ZZE122_FMIC.jpg
http://www.purcellperformance.com/1zz/ZZE122_Manifolds.JPG
http://www.purcellperformance.com/1zz/ZZE122_Turbo.JPG
http://www.purcellperformance.com/1zz/ZZE122_Pipes.jpg
http://www.purcellperformance.com/1zz/ZZE122_Turbo2.jpg
http://www.purcellperformance.com/1zz/ZZE122_V44.jpg
Edited by CHA54
thanks for all the reply's guys
i dont have any pics of the car and nothing has been done to it by me, nor has anything been done by previous owners.
i didnt expect the cost to be that big, although this is the first time i have looked into something like this hahahaha
my firend has been doing cars up for a couple of years and told me he seems to think i can get away with turboing my car for about $1200 so il have to have a word with him lol
i will have a look at the thread at the top for the faq and go from there i think
thanks everyone again i appreciate your time to help
mealsy
If it was $1200, Most cars on the street would have Turbo :)
Once again, i dont see you getting Turbo in your car :P
I would like a turbo setup for $1200. what a bargain, but seriously, thats all it is. lol
End of the day, you gotta take into account also the downtime with having your car worked on. Do you have another car to use while the turbo setup is being installed? It may take a few months + whatever customisation needs to be done + any extra parts they need to source + tuning and getting the right setup. Might not be a simple job. At the end of the day, it could end up costing you a lot. Workshops charge you labour on everything, and it really ends up destroying your wallet.
There is a thread here regarding a turbo update ,please search
Here is one turbo kit from Phillipines, for Toyota Corolla Altis, this car is popular to modify there
http://www.speedlab.com.ph/turbokits.php
just to throw in the idea...why not a supercharger?
it heard a TRD or blitz supercharger is a lot easier to install plus if you have more control on your acceleration over a turbo. One of the guys from this forum in brisbane has put a switch on his supercharger so it drives like a normal corolla and is fuel efficient when he just wants to do normal driving.
just an idea
The TRD supercharger is relatively easy to install but doesn't offer a massive power gain. The hard part is finding one in good condition with a decent idler bearing and bracket these days. The TRD charger also doesn't use a clutched pulley so it's effectively on all the time. The blitz charger uses a clutched pulley and costs a hell of a lot more than the TRD chargers.
      RADIO CODES "HELP"
    4. 2
    7. 21
    8. 21
    9. 21
