levin ZR headlight out
Can someone give me details on those pair of so bright and white parking light, I want to change them to match the HID.
T10 6 SMD LED Cool White
Are these what's in your ZRE ? any good for a reverse light?
or you can get HID Reverse lights ;)
too expensive thought .. $140 <_<
ill get them when they reach less then or equal to $80
edit: without the spaces ... for some reason its not working ..O_o http:// m a x v i s i o n a u s .blogspot.com/2011/06/hid-reverse-light-back-lamp-system.html
Those are fitted in the front parkers only.
I believe the reverse lights are T20 's (7440), I've been holding back buying these, for obvious reasons, but might soon enough.
John, you asked earlier about the Brake Lights(T20/7440), these might be bright enough.
Correction:
Brake Lights (Outer Bulb): T15
Rear Parking Lights (Inner bulb): T10
Reverse Lights: T20
Update: I have installed these in the reverse position:
  • 4 years later...
Did anyonr actually get their globes via toyota for the cheaper values mentioned?
As i popped past two dealerships today (Adelaide) and both quoted identicsl $339.00 prices per globe. Still blows me mind that high volume manufacturer would use such ridiculous priced items (or attempt to rip their customers off)
Hi All,
I have a Corolla Levin SX 2013 and would like to change the factory globes to whites ones. I did a search  and was advised H11, however these globes dont fit this car.Could you please suggest/advise which globes to get and from where.
The existing glob is for high beam as well, so could you please advise.
VJJP.
      ASV50 Camry Head Unit Options
    5. 14
      Hi from Wagga
    8. 2
    9. 2
    10. 2
