Hi folks, I own a 95 Commuter, bought it to build a camper which I did.
But now I am wondering where to find the fusebox and also the wiper water tank for front and back.
I owned to many cars so far but I just can't find it in that van.
Does somebody has a clue ?
Cheers
Chris
  • 4 weeks later...
Wiper water tanks are usually on the left hand side. Rear should be accessible from just inside the rear swing up door behind a little access cover. Front one normally has a fill point just inside the front passenger door on vans.
Fuse box could be inside the passenger footwell or under the steering column. Often there is a seperate fusebox inside the engine compartment for all the engine related fuses as well.
thanks mate, right in the door step of the passenger side, would have never expect it there!
may I have another question? turn light indicator not working and doesn't make a sound anymore, both, normal indicators and emergency ones.
Haven't found a broken fuse, wondering where the relay is. Maybe that one has to be replaced.
thanks
Chris
    2. 0
    3. 9
      Android auto
    4. 9
      Android auto
    5. 1
      Turboed Corolla Overbuilt?
    6. 3
    7. 3
    9. 18
