loose feeling on front wheels
SASO1
I have massive play on front end of car as you take off, car goes left and right....also it has a funny noise as if arm rod's are loose..
Does anyone have that issue with trd, Aurion?
Saso1
The TRD is susceptible to all issues that the normal Aurion experiences. Do a search on the Aurion forum to read more about the various issues including pulling to the left and knocking during acceleration and braking. These issues have been discussed time and time again on this forum. As well, things like torque steer, which the Aurion also has a bit of, are more pronounced on the TRD due to the extra torque.
As for the play in the front end, as you may be aware the Aurion is FWD, so depending on how hard you accelerate, the steering can be a combination of being light and pulling to the left or right due to a combination of all the above factors.
Just sounds like torque steer really. You'll soon adjust your driving style around this and in time it'll seem less pronounced as you become a little smoother lol. But it may pay just to get it checked over make sure everything is tight and as it should be in the front end. Even if it just puts your mind at ease.
Saso1
define take off. It seams like your take offs are a little more lead footed than the average motorist.
    2. 16
      2000 Corolla Ascent - clock.
      ST205 for sale
      Rukus for sale
    6. 8
      CH-R sudden engine failure
      2Door 1975 KE30 Corolla 4Sale
      Hi from Wagga
