Hi was just wonder if people had seen projects to this hp . And what they were doing to get it .thanks
Very improbable*......yet I would like to hear what the max hp people have seen a 2zz at...and how they got there...
*anythings possible with enough $$$$$$!!!!
400hp is do-able on a 2zz.
Wiseco pistons
Darton sleeves
GT35 turbo
MWR rods
full ECU
Some head porting
255l fuel pump
return fuel system
probably need 800cc/min injectors
You'll have issues with the manifold as the power steering is in the way, but CES Racing built a manifold that avoided it before.
Probably about $20k on the engine and plumbing alone (if paying someone).
Posted (edited)
monkey wrench racing has a 823 front wheel horse power celica
and it has done 202 miles per hour on a straight
thats what money can do for you
there WAS a 208 fwkw turbocharged zzt231 in aust
there STILL is a 227 fwkw supercharged zzt231 in aust (and has more potentials)
Edited by anhphuongvu
Posted (edited)
Apparently the MWR manifold works for the RHD Celicas so long as you are happy to run a very skinny filter connected directly to the side of the turbo.
Edited by T_Money
Yeah was wondering about those piper cams . And how they go .
How about the 248fwkw Sportivo owned by our very own moderator Xoom?
USHP, so can reduce it by 10-20% to be more realistic. Still impressive though.
They have more overlap than the stock cams so don't tend to hold the pressure in as well. But that said they have more lift so can let more in. I'd go with stock cams if I was going FI.
Essentially the same engine and drive-train though so wouldn't make much difference...
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
