Scuff plate for TOYOTA HILUX!!!
HZJ78 TO HJ75 door compatibility
Welcome to the forum Kelvan, I am sure if anyone can help they will KAA -
Leaving a Camry Hybrid at the airport for 10 weeks?
If it makes you feel better, I also don't know the answer to your question -
5
No adjustment was necessary. Spedo on 100km/h shows a 97km/h on Ways/Google Maps so seems the auto may recalibrate itself back to somewhere close to factory. Tyres are 33.2" which comes in 1.6" larger than standard. Have also added an ARB long rage fuel (sub) tank. However the computer doesn't pick this up, extra 45 ltrs. Maybe an aftermarket hack somewhere but no big issue at this stage. -
Is it possible for the 3.0L 1KD engine to be in a 2020 Prado
Was wondering if this is a scam. Guy selling what he says is a 2020 Prado TXL but says it has the 3.0L 1KD engine, is that possible? Everywhere I read says in 2015 the engine was changed to the 2.8L for the Diesel version. This is in Honduras. -
592
JOKES !!!!
"The Far Side" by Gary Larson has some cartoons that pertain to cars & driving:- -
10
Further update, Toyota had my vehicle all day and fitted the new camera; bloody thing did not work. So much for their diagnosis of an open circuit in the camera! Now I am told that I am going to have to remove all accessories out of the rear of the vehicle, so drawers, fridge and slide, battery and electronics that are all connected through to the main battery and solar system so that they can access the wiring in behind the side panels and drop the roof lining to further diagnose. Quoted me around $500 to remove all of these components so going to do myself and they are suspecting that the issue is going to be mine and not covered under warranty. The day after they fitted and removed the new camera, the rear vision started working for one day then died again so I am suspecting a wiring issue maybe through the tailgate or that as others have advised there is a faulty sensor under the passenger side dash that feeds into the infotainment system. I have mentionbed this sensor to Toyota on two occasions now and been fobbed off and not fault diagnosis undertaken that I am aware of. -
rattle from the motor.
Here we are at June 21. After another round of mechanics workshops, the full timing chain and all parts have been changed, the catalytic (upper inc. the manifold,) converter, oil pump. Still when started cold it's a loud clatter, that is irregular in loudness and frequency. As it warms that decreases in loudness and consistancy, but can still be hears. When at idle, I increase the rpm to around 1500-2000 rpm, the sound fades to nothing. Please help. The mechanics have not, but I'm 5k poorer. -
5
Any requirements for adjusting the computers etc for an increased rolling diametre. -
2008 200 series starter sticks in a few seconds after sitting
What was the solution plz -
A major Electrical problem on 2013 Grande
haha nice to see your Kluger still going strong! Is your suspension still stock or you went with a lift for your road trips? I've decided to try keep mine for another few years so looking for lift kits for those long road trips when I get to pack the house with me.
