Just finished logbook service for 80k km in Toyota service centre, but next morning it is hard to start my corolla car. And I travel in freeway when speed over 100km/h car start to shake
Anyone knows whats wrong with my car
define shake.. like as in the steering wheel vibrated ? or something else ?
could be wheel alignment or tires, or even the road you're travelling in,
The the wheel and whole car body is shake like u seating on a massage seat
Lack of power as well?
Of yes, one of cylinder may not be working properly.
did they rotate your wheels? the vibrating in the seat means rear wheels aren't spinning straight. vibration thru the steering wheel means the wheels at the front aren't alligned or not on properly. i SUGGEST you jack up each wheel and check that the wheels are on straight and flush with the hub
Thank you but tires are good and when I travel below 100kph everything is good and when travel at 110 kph shake happen
And does anyone know which Toyota dealer open today? Nsw and Vic area
most vibrations only occur once u reach high speeds. this is becuz the wheels dont spin fast enough for you to feel it. no toyota dealer is open today. i suggest also to take it to a reputable mechanic in your area. i for one do not trust toyota dealers diagnosing things like this. u may spend ALOT more money than necessary
Assuming that the whole car shakes like a massage seat, I don’t think wheel alignment and balance is the culprit… :g:
Misfiring seems not probable?
I know on the BA Falcons the ABS module have the common fault of pulsating causing similar symptoms, but haven't seen one on these Corolla…
      Tyre Sale Specials
    2. 0
      overheated engine
    3. 1
    4. 62
    5. 1
    6. 1
    7. 1
      Tyre Sale Specials
    8. 10
      Android auto
    10. 0
      Remote start
