HI all!
So i'm thining of painting my calipers but does anyone know how to take them off and put them on again? I mean I don't want to mess around with brakes without getting some instructions!
ok... what about how do i remove the break pads?
take the wheel off :)
2 bolts, can't remember exact size will let u remove caliper, theres another 2 if you want to remove the caliper + mounting bracket.
pretty straight forward as long as everything goes back how it came out
Posted (edited)
17 mm bolts for the calipers on the front 14 mm the the rears :)
your best 'NOT' to just spray and pray so to speak .....as the VHT paint tends to turn to rubber and makes the pads very hard to remove at a later date
Edited by Danthuyer
ok then, Do i need to remover the caliper to remove the break pads?
If not (or if so) pls give instructions?
Posted (edited)
yes you need to remove the top section of the calipers to change brake pads
Instructions?
go to the workshop section and download the corolla manual and have a lewk :D
GO HERE
Edited by Danthuyer
      Remote start
    6. 10
    7. 10
      Turboed Corolla Overbuilt?
    9. 3
    10. 3
