Posted (edited)
hi guys, i was fitting some new LED globes into my gear selector slot and as i turned the light on to check it out, everything blew in the centre console, but the door and dome lights were still working. I checked the fuse and it is still fine. What have i just done!!!??? is there another fuse for the centre console, AC and Radio lights? Or have i blown every single light globe ? :unsure:
Edited by toyota pride
Hey Toyota Pride,things like that sure send a panic thru the old brain hey.Mate did you check all the fuses in the cluster behind the glove box as well as in the engine bay.Try putting your original globe back in if it works try putting the LED back in and if it dont illuminate rotate the LED 180degrees as from memory they are polarity sensitive,
hope you sort it out champ;
cheers CONROD
Thanks for reply conrod, i tried a new globe but she won't light up, and i did that 180 flip and still no success. I shall have a look at all the fuses under the dash which may relate to interior lighting. I hope it is a fuse.
All is good! i looked under the dash, and it is the fuse listed under "panel" it is a 7.5 amp lucky i had some spare, so now everything is working :toast: And now i got nice blue led lights illuminating my shifter.
Good to hear it was only the fuse mate
    2. 0
      Remote start
    3. 1
    4. 0
    5. 9
      Android auto
    6. 9
      Android auto
    7. 1
      Turboed Corolla Overbuilt?
    8. 3
    9. 3
    10. 0
