DIY LED illuminated door handles
phatYRs
hi everyone, just wanted to spred the word about the DIY topic LED door handle install,
while the DIY post (its on this site, just search DIY LED install) explains in great detail how to attach the lights it gives no real explanation on how to wire them.
i have a 2010 YRS sedan and after much testing, asking and yelling i finally figured out how to do it (insert face palm lol)
the dome light has 3 wires going to it.
i found a full yaris wiring diagram here http://www.scribd.co...ecret_password=
a blue one=constant power
a white and black one=earth
and a purple one=power switching
once you have installed the lights in each door and ran the wires to the B pillar, you need to run a power wire from the battery (with a fuse installed as well) and splice the power wire for each LED to this power wire.
once this is done connect each earth wire from the LED's to the purple wire (power switching) and hey presto!!!!
all done here's some picspost-26104-0-61866200-1335091606_thumb.jpost-26104-0-38447700-1335329324_thumb.jpost-26104-0-59733700-1335329409_thumb.jpost-26104-0-27469900-1335329464_thumb.j
Edited by phatYRs
      2012 Hilux 3.0 D4D starts, runs for 30 seconds then stops
    2. 24
      FUEL WARNING MESSAGE
    3. 24
    4. 24
      Hilux 2017, 2.8 diesel dual cab - alternator
    6. 32
      toyota 700
    7. 4
      'Please check the SD card' - Does anyone have the SD card files?
    8. 1
      Adding cruise control to a 2008 Ascent Hatch
    9. 32
      toyota 700
