When I start the engine the lights on the dash go on and then go off once the engine has started. I've recently noticed that the airbag light stays on longer around 4 or so seconds after the other lights turn off then it just turns off. Just wondering is this normal?
As long is it goes off the system is working just fine.
sweet, thanks man!
Yup, it's normal. Mine does that every so often too! It's only a problem if it doesn't turn off, or turns on again while the engine is running.
      Remote start
    5. 9
    6. 9
      Turboed Corolla Overbuilt?
    8. 3
    9. 3
