Hi all,
I own a trd aurion, lately i have had a problem with turning on the car. When i press the start button it turns the engine but takes about 3 seconds to ignite. This only happens when the car is cold.
Can you please share your thoughts as to what it is.
Thanks all
3 seconds is hardly a "long" time to crank before firing, especially when the car is cold.
Hiro,
Its not normal. It last 5 seconds sometimes. It just doest feel right and it recently started happening
Taken the spark plugs out and had a look at them?
Battery could be on its way out or the alternator might not be charging it (more likely to be a battery issue though)
  • 1 year later...
I have had this issue too except sometimes when the engine is warm it still happens.
It was happening when I bought it with 35,000k's on the clock, changed the battery at 50,000k's > no change.
I am told I am due for new spark plugs now (at 90,000k's), so we will see if that helps. I am not optimistic since the spark plugs should have been fine when I bought the car.
Any other possibilities.... starter motor???
      Remote start
    2. 1
    3. 0
    4. 9
      Android auto
    5. 9
      Android auto
    6. 1
      Turboed Corolla Overbuilt?
    7. 3
    8. 3
