camry aurion ducktail fitment
linhvo
hi guys
im currently after a ducktail for the aurion
However im inlove with the ducktail that comes on the camry sportivos.
im not really sure if the camry one will still fit the aurion because i noticed that the curvature / shape of the boot on camrys are slighty different to those of the aurion.
does the camry one fit the aurion or are they different
help :(
post-29722-0-07592700-1355209491_thumb.j
I don't think the camry ducktail will fit without a fair bit of work. Depends on how much time you want to spend making it fit I guess. Otherwise, a ducktail for the aurion is available from bodykits kingdom in Brisbane at the moment for around $150. Saw them advertised on ebay the other day. I think it is the same one as mounted to my car but can't be sure as I bought mine from elsewhere.
I have my aurion and my dad has a Camry with a ducktail. I just parked them next to each other and the boot shape looks identical apart from the cut out for the tail lights. So IMO I should work fine
