Sportivo Stud Pattern?
masasaki
yes
Thanks Jeff :) Also I'm thinking of getting 19s what tyre size would you recommend?
Not really sure on tyre sizes, but if you use tyre size calculator you should be able to get a better result to match your speedo from transitioning 16" (or 17" im just assuming your stock rims) to 19"
Hey Guys, I'm thinking of doing something similar to my 97 Svx20 Camry Csi. Does anyone know whether the bore size(the hole in the middle of the Wheel)is similar to other Camry's or Can I use Ford Xr6 or Xr8 17" rims? I understand you can get reducing collars to bring the diameter down. The Camry Bore is supposedly 60.1mm.
Has anyone fitted such rims to there Camry's?
yes
What width? Guessing something like a 19x8.5, 19x9 around there? Something around 235/40/19?
I've got 19x8.5 on my other car and you'd need atleast 235. go the 35 series. For 19x9.9 i recon you need 255 wide tyres.
      Corolla Seca For Sale
      Toyota Corolla Sportivo
    6. 2
      Toyota Landcruiser problems
    9. 7
      selling car
