CD player doesn't load CD!!!
nmocha
Hi, I am new to the forum and I just bought an used aurion today!
it is a 2008 prodigy and I have trouble using the CD player!
I pressed the "load" button and the word "WAIT" comes out from the screen but then it doesn't have the "load" word come out. I tried to put a CD in but it doesn't suck the disc into the player...
did i do anythings wrong? or, is the CD player simply is not working?
thanks
not sure if you can separate the aircon/CD stacker, but the Prodigy will have digital climate control so if you can't seperate it then that won't work. And also that one is not a CD stacker, its only a CD player.
Edited by nzzr6
Nmocha, if you bought the car from a dealership, take it back to them and get them to look at it. You will still be covered by the statutory warranty. Otherwise, if you bought the car privately it might still be worth taking to the local toyota dealership to look at. At least they will tell you if it's a simple fix or if it's stuffed.
you can separate the aircon unit
I bought the car privately :(
an update for this case, I restarted the car this morning and the CD player actually "load" the CD!!!
However, it shows "Error 3" message after sucking the CD and won't play anythings...
I tried 3 CDs (2 originals and 1 burnt) and all come up with the same result, any clue?
it is now able to eject and load cds though
If your feeling adventurous it might be worth unplugging the CD player all together from the car so it resets all the defaults etc, and then plugging it back in to see what happens.
      2013 cruiser gxl ute
      help with clutch
    6. 3
      newbie from Queensland
      High mileage camry
      1981 Hiace ignition upgrade
    9. 2
    10. 1
